What's the best aftermarket programmable computer for a SD TPI?
Old Jan 21, 2001 | 01:37 AM
TPIi's Avatar
Yes, I'm gathering parts to install a speed density TPI system in a Toyota Landcruiser with a Chevy drivetrain. If you can give examples of good units with increasing price ranges that will be sweet. thanks for your input. I am inquiring about this possibility because I've been informed that it could be hard to burn a good chip for a vehicle with so many mods.
Old Jan 23, 2001 | 09:30 PM
steve8586iroc's Avatar
Check out the Holley 950 Commander ecm at www.holley.com It sells for aroumd 550.00.
You will also need a wiring harness that sells for around 200.00 to 250.00.
Steve
Old Jan 24, 2001 | 08:14 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
One of the most expensive (and in my opinion the ultimate) is the FelPro SpeedPro unit. These range in price depending on the options that you choose. One of these units with wide band O2 and sequential fuel injection will fun you ~ $2500. Just wanted to give you an idea as to a more 'topend' unit.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Jan 24, 2001 | 08:27 AM
88GTASTK's Avatar
The Felpro is one hell of a unit. Real easy to use and just enough features to be effective without overwhelming you with changeable parameters. After taking a look at Tunercat with the TDF for the 90-92 TPI speed/density cars, there's more options with the GM ecm. It does look like it won't be as easy to work with as the Speedpro and doesn't support a wide band O2 sensor, but there is more there to work with.
Anybody have any first hand experience with the new Holley system ?
Paul
Old Jan 24, 2001 | 01:37 PM
87Z-ya's Avatar
About time aftermarket setups were talked about on here. Even though this is the prom board.
Old Jan 24, 2001 | 11:44 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
No more so then with a aftermarket ecm.
reversion, is a constant. MAF MAP other then Aplha-N always will be.
Aftermarkets tend to be less detailed so easier to work with.
Finding a spare Speedpro on Sat night can be an adventure......
rather carry a $25 spare gm...
stalkier
Dec 6, 2015 11:25 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
