MAF TPI Computer
Old Jan 23, 2001 | 09:16 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
MAF TPI Computer
I have a 1986 TPI car. We are building a 355 with AFR heads, long tubes, and xtreme cam. We burnt the computer chasing some eleectronic gremlins. Should I just get a stock computer for this model year or is there an advantage to going with another year computer(can not afford aftermarket computer) I read in one of these posts that someone was switching to a 1989 ECM. They are still MAF, so any advantages? I want to keep the MAF for now also.(AFR heads are expenssive :-))
Thanks for any and all help
Chris
1986 305 TPI
8.0 @88 in the 1/8
**Soon to be 355
Old Jan 23, 2001 | 09:19 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
hrm, welp, i'm not too familiar with your year, but i believe you have the cold-start injector and the 89's don't. So there would be one advantage. Other than that, i'm not sure.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Problems every other day with the car (probably not a mod, but to me it sure makes a difference)
Old Jan 24, 2001 | 08:11 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
There is no difference between the '88 and '89 ECMs. They are the same part number. The difference is in the PROM. '88 PROMs ($32B) were designed to use the cold start injector. '89 PROMS ($6E) were designed NOT to use the cold start injector. '89 was also the year that GM updated the microcode in the backhalf of the PROM bin. However, I don't have details as to what they changed and why.
So - long story short - it doesn't matter if you go with an '88 or an '89 ECM because they are the same. I would recommend, however, that you use an '89 bin as the base image for your tuning.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Jan 25, 2001 | 08:22 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Since I am new to this, a bin is what I program into the chip, sort of like a starting point? Where do you get blank proms?? How much are they?
Chris
1986 305 TPI
8.0 @88 in the 1/8
**Soon to be 355
Old Jan 25, 2001 | 08:23 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
oh yea and what is $32B and $6E
Thanks again
1986 305 TPI
8.0 @88 in the 1/8
**Soon to be 355
Old Jan 25, 2001 | 07:48 PM
gravitar's Avatar
I don't mean to turn this into a "for sale" ad, but if you don't have a replacement ECM already, and you don't have easy (cheap) access to one, let me know. I have a few of them. Scored one last weekend out of a '91 S-10. The '91 Tech-4 S-pickups are a good "unknown" source of '165 ECMs, by the way.
Anyway if you need one, e-mail me.
Old Jan 26, 2001 | 11:28 AM
TRAXION's Avatar
NufNuff,
Read the PROM burning article ....
https://www.thirdgen.org/newdesign/tech/promintro.shtml
Then, read it again. It answers the questions you asked.
Tim
Keith5
Aug 27, 2015 04:37 PM
NBrehm
Aug 25, 2015 11:49 PM
theurge
Aug 21, 2015 12:46 PM
perZ
Aug 15, 2015 01:17 PM
Sanjay
Aug 12, 2015 03:41 PM
