EBL: VE Tables - 2000 RPM in both tables
Old Jul 8, 2006 | 08:30 PM
elkabong's Avatar
Car: 84 Vette
Engine: 383 XFire
I have noticed that in both VE tables there is two row's @ 2000 RPM. What is the difference between the two row's?
Old Jul 8, 2006 | 09:48 PM
DM91RS's Avatar
Car: 91 RS
I noticed that right away when I first got the EBL. I ASSumed they were the same and just done that way for referance without looking at the other table.
Now after many VE Learn sessions they have the same values on both.
HTH............DM
Old Jul 9, 2006 | 08:39 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The 2,000 RPM row in each of the two VE tables is to allow a seamless change from one table to the other. Both rows should have the same values in them.
As an example of where each is used, at 1,950 RPM, the low speed VE table is in use. It will be using the 1,900 RPM and the 2,000 RPM rows in the low speed table in forming the VE% value.
At 2,025 RPM, the high speed VE table is in use. It will use the 2,000 RPM and the 2,200 RPM rows from the high speed table in forming the VE% value.
The code interpolates between the rows to form the VE% value.
RBob.
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
wisemanz28
Sep 20, 2015 01:26 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
ULTM8Z
Sep 16, 2015 09:15 AM
challenger71
Sep 10, 2015 04:58 PM
