Correct Pins on ECM for MAP
I am in the process of trying to figure out if my MAP sensor has been wired correctly to the ECM. Does anyone know the correct pin numbers for the wires leading from the MAP to ECM.
Is there any other way to check to see if teh ECM is reading the MAP correctly?
Car: Death Mobile
Engine: 666 c.i.
I didn't think the 165 ecm in 1986 used MAP. Did you convert to MAP or do you mean MAF?
Yes you can check the MAP (if it truly is a Speed Density system). Either with a multimeter or with a scan tool.
