laptop/diacom help
Old Feb 24, 2001 | 01:29 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
laptop/diacom help
I already have diacom+ gona go get a old 386 to use it on.
My question is how would I make a commamd like for one of the F keys to auto matically run/start the dicom program on boot up.
Chris
1992 25th Anniv Z28 W/383 Stroker
536 RWHP 569 FT LBS
(chassis dynoed at Ramsies Perf.)
www.go.to/TPI383
[This message has been edited by TPl383 (edited February 24, 2001).]
Old Feb 24, 2001 | 02:03 PM
Dirk's Avatar
TGO Founder/Former Owner
Car: 1992 GTA
Just install DOS on the machine. Then edit the autoexec.bat file and add a line at the bottom to start Diacom. When the computer boots, it'll parse the autoxec.bat file and it'll find your Diacom line and it'll start it automagically. That's how I have mine set up
Enter something like:
c:\diacom\gmecm.exe
Or, if you want to use a path statement:
PATH=c:\diacom\
gmecm.exe
that'd work too.
I'd recommend the first method. Good luck
Old Feb 24, 2001 | 11:41 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I do something similar to Dirk, except I have a BAT command called D.BAT in the "root directory" (same directory where autoexec.bat is. It has the same command that Dirk typed for the first option.
Then I just type "D" when in DOS and executes Diacom. This is useful because my "old notebook" has W95 and I use that for TunerCat. So I just swap between Dos and W95.
But if you have nothing except Diacom on it, then I'd do as Dirk suggests, since it has no other purpose.
[This message has been edited by Glenn91L98GTA (edited February 24, 2001).]
Old Feb 26, 2001 | 08:51 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Thanks guys.
