injector bias Q?
Old Jul 13, 2006 | 11:55 AM
Ronny's Avatar
injector bias Q?
why is above a tuneable parameter?
i did some reading up and i understand there is a time element restriction to fuel at higher rpms with TBI(2). the injector has to be open sufficient time to fuel the required A/F and then close for next opportunity. i see a chart that refers to "PWM time" which appears same as above terminology. thay suggest for low impedence injs that time to open is 1.0 msec. they dont state it a variable but a defined time.
i assume our inj's are low impedance?
the time to open is variable ? i can see voltage changes as one variable but assuming voltage adequate(11.9+) why a tunable parameter? seems the off time before next on would be the determined by command from ECU to achive the A/F? i am about to change the bias for more fuel PE.
Old Jul 13, 2006 | 03:25 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
The opening time characteristics vary by injector. Depending on pintle weight the injector might have a design on the low end of allowable resistance. When they start fudging coil designs to get better opening characteristics, you can count on the opening times being a variable.
If you change injectors and, and injecotr BPW (ie doing the proper math), then a VE table should be correct with no changes. If not then the opening time variable is *off*.
Old Jul 13, 2006 | 07:30 PM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Ron,
When you get the chance to look at the EBL code, you'll see that the IB(Injector Correction Offset) is variable on the basis of voltage. I think your question has to do with "why is IB adjustable in the $42def". As Bruce has said, it allows for the use of various injectors. All the stock bins I have seen use an IB of 396msec. RBob however tells me that he has measured the opening time for BBC injectors like ours and its in the 700+msec range.
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
