What should I program for 30# injectors?
Old Mar 12, 2001 | 09:47 PM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
I am installing 30# injectors and I sent my Level 4 PROM back out to TPIS for reprogramming. What should I ask them to change. Look at the mods below to determine what should be done. Thanks.
Joe
1988 GTA 5.7L TPI Auto
355 ci. block, SLP Cold Air Intake w/ K&N, fully modified MAF Sensor, TPIS 52mm Throttle Body w/Air Foil, Fully Ported and Polished Plenum, Nikel-plated Ported SLP Siamesed Runners, Ported TPIS Big Mouth Intake Manifold, stock heads w/ 1.52 Comp Cams Self-aligning Roller Rockers, TPIS ZZ-9 Roller Camshaft, TPIS Valve Springs, Cloyes True Double Roller Timing Chain, TPIS Adjustable Fuel Pressure Regulator, Ford Motorsports SVO 30 lb/hr Fuel Injectors, MSD 6AL, Taylor 10mm Wires, Bosch Platinum +4 Spark Plugs, MSD Blaster Coil, MSD Shift Light, March Underdrive Pulleys, 6 3/4" Vibratech Streetdamper, TPIS Level 4 PROM, 160 T-stat, Low Temp. Fan Switch, Stock Distributor w/ Bronze Gear, SLP 1 3/4" Headers, Random Technologies High Flow Cat., Adjustable Borla Cat Back Exhaust, Flow Tech Pre-Cat 3" Exhaust Cut Off, ZR1 Heated O2 Sensor, Level 10 PTS-3 700R4 Trans, B&M Holeshot 2400 Stall Converter, B&M Trans Cooler, TCI Aluminum Finned Trans Pan, Torque Converter Lock Up Switch, 3" Balanced Aluminum Driveshaft, 3.73 Richmond Gears, Auburn Pro-Series Differential, Aluminum Differential Cover w/ Main Cap Preloads, BF Goodrich Drag Radials 255/50 R16, Hotchkis Lower Control Arms, Hotchkis Panhard Rod, Hotchkis Tie Rod Adjuster Sleeves, Bilstein Heavy Duty Shocks and Struts, 1LE Springs, Energy Suspension Polyeurethane Bushings, Global West Tubular Subframe Connectors, Global West Steering Box Brace, HP Motorsports 3 Point Strut Tower Brace
"Why ride a stang when birds can fly?"
http://www.geocities.com/thegta
Old Mar 12, 2001 | 10:51 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
For them to simply change the PROM to work with 30lb injectors it will take approximately 15 minutes including erase time. They will probably charge you at least $100. I say that it is worth about $10 + shipping. This is something that is so rediculously easy. You should do this yourself. And - TPIS will probably burn your chip for 30lb injectors when they really should burn it for 33lb injectors because the SVO injectors are rated at a different flow.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Mar 13, 2001 | 10:07 AM
Thanks Tim. TPIS said that they would do it for free. I was planning on doing it myself but I'm waiting on a friend of mine that is getting the burning equipment. Can we copy the PROM that TPIS has made and burn it into the stock PROM, and then modify it? Can we save the info on the the stock PROM just in case we need to return to it? We are very new at this so we will be needing some help. Thanks again.
Joe
Old Mar 13, 2001 | 02:09 PM
TRAXION's Avatar
Jo,
Read the article linked at the top of this page. Understanding that article is the key. Yes, you can save the original BIN file and yes you can write to the existing chip.
Tim
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
