programming help
Old Mar 15, 2001 | 12:29 AM
enloe's Avatar
programming help
I have been using Tuner Cat software with great results at part throttle. My scanner indicates O2 readings of 960-980 mV at WOT accross the RPM range. This seems a bit rich to me. I have been subtracting fuel in these areas with no noticeable difference. I have been making small changes to keep from getting carried away but so far I have subtracted a total of 5% of fuel at 95-100 KPA. My 92 vette is fairly stock. Is more than 5% normally required to bring the O2 sensor readings down to the high 800 mV range? The changes that I have made at part throttle were small but very noticeable and I am sure that my car and equipment is in good working order. Any input would be great. Thanks
Old Mar 15, 2001 | 08:47 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
If you are concerned with WOT you may want to try subtracting fuel from the WOT PE vs RPM table.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
djmarch
May 8, 2016 11:32 AM
ULTM8Z
Oct 2, 2015 01:25 PM
bryanwood74
Sep 24, 2015 09:50 PM
f-bodyz28
Sep 2, 2015 05:03 PM
bdads
Aug 24, 2015 06:01 PM
