Interesting problem with 6e code
Old Mar 26, 2001 | 01:04 PM
gsf-87IROC's Avatar
Car: 87 IROC-Z
Engine: 383 HSR $8D
I don't know if it's Tunercat's tdf file for the 6e code or what...but in MAF table number 4, the counts go from 1216 to 1284 back to 1280 at the end of the MAF 4 table.
Do all the 6e files do this or is it a hiccup in tunercats tdf?
GregF
87 IROC
Old Mar 26, 2001 | 01:10 PM
mike89z's Avatar
Car: 89 Iroc-Z
Engine: 355
Sorry, but its just you. Mine are all fine. It must be somewhere in your tdf file. Those two bytes of info where swapped 1284 instead of 1248. You should probably try reading another bin just to make sure its not that.
355 10:1 , AFR 190 heads, LT4 HOT cam w/ 1.6 roller rockers, complete Superram intake, 58mm BBK TB, 24# injectors, screens out of MAF, MAT relocated, March underdrive pulleys, Streetdampner, Crane HI-6 ignition, 160 thermostat, K&Ns, TES headers(Jet hot coated), Mufflex 4' cat back, B&M shift Kit, 2500 converter, and 3.27s.
Old Mar 26, 2001 | 04:22 PM
gsf-87IROC's Avatar
Car: 87 IROC-Z
Engine: 383 HSR $8D
ARGCH?!?!? Hmmmm, so it's just me...eh...well something must be screwy in my tdf file then...I'll take a look at one of the older one's if I still have it.
Thanks for checking...
GregF
87 IROC
Old Mar 26, 2001 | 04:56 PM
gsf-87IROC's Avatar
Car: 87 IROC-Z
Engine: 383 HSR $8D
Ummmm, disregard this post...checked my tdf file at home and it's fine...I have an older copy at work and it is fubarred....mental note to self...
anyway, anyone with the 6E def file you might want to check and if it's mucked up...get a newer one from Tunercat...
GregF
87 IROC
Old Mar 28, 2001 | 01:41 PM
Desert86Roc's Avatar
I just checked my .tdf file, and those same bytes are swapped. I just got mine last month, did they upgrade/correct it since then?
Mike
Old Mar 29, 2001 | 11:11 AM
gsf-87IROC's Avatar
Car: 87 IROC-Z
Engine: 383 HSR $8D
<font face="Verdana, Arial" size="2">Originally posted by Desert86Roc:
Mike
</font>
I believe so...I think mine is Rev N Check their website...they have a list of current revs there.
GregF
87 IROC
Old Mar 29, 2001 | 01:42 PM
Yep...got it... thanks.
Falcon50
Aug 22, 2020 03:26 PM
db057
Jan 10, 2020 08:55 PM
Luigytico09
Oct 1, 2015 08:46 AM
3rdgenkindagal
Sep 13, 2015 02:02 PM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
