Wiring the VSS into computer harness / ALDL to get to work on DIACOM
Old Apr 7, 2001 | 10:25 PM
Steves ZZ5's Avatar
I did a search, and didnt find any posts on this.
I've got the Miniram and the TPIS '90-and-above computer and wiring harness on my '86 T/A. The system is Speed Density.
Since the trans or computer doesn't use a VSS signal for anything, TPIS never included a wire in the computer harness that the VSS would hook up to. I had to run a hardline from the VSS to the speedo to get things to work in that area.
My main question is how would I go about hooking the VSS wires into the computer connector in order to get Speed information to be processed and be outputted through the ALDL so it can be read on my Diacom?
I'm sure that any of you running the Miniram (and other custom setups for that matter) have seen what I'm talking about. I'd really like to have the MPH info so that I can compare everything when I go to graph my runs prior to chip work.
Thanks guys
86 Trans Am WS6 Black with tinted windows, shaved door handles
ZZ4, Mini-ram, true duals
***Too many other mods to mention***
"In the future, cities will become deserts,
roads will become battlefields, and the hope of mankind
will appear as a stranger"
The Road Warrior
Old Apr 9, 2001 | 09:51 PM
Steves ZZ5's Avatar
Hmmmmmmm.....anyone have an idea?
Anyone know the Pin-out?
Old Apr 9, 2001 | 11:22 PM
Brent's Avatar
http://www.diy-efi.org/gmecm/ecm_info/1227730/
The SD 7730 pinout is at the bottom of the page.
Old Apr 10, 2001 | 01:27 AM
Steves ZZ5's Avatar
Thanks Brent.
I'll be checking the pinout portion of that website when I get home in the early morning hours. Can't connect to the ftp portion of the site here at work for some reason.
Again, thanks so much for the link...probably just what I was looking for.
Old Jan 6, 2008 | 05:59 PM
jcs64's Avatar
Re: Wiring the VSS into computer harness / ALDL to get to work on DIACOM
Is there anywere else that I can find the file that Brent was refering to, It sounds like thats what Im looking for but I cant get to that site (I think they went under)
Jorlain
Aug 24, 2022 05:11 PM
midge54
Sep 2, 2020 07:13 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
jharrison5
Aug 19, 2015 05:53 PM
