Will my scanning/tuning software work on a 93 Z-28?
Old Apr 20, 2001 | 03:35 PM
shawn87gta's Avatar
A friend has a 93 Z-28, LT1, which I believe is a SD setup. I'm curious to know if the same scanning and tuning software for the thirdgens will work for his setup, are the proms the same, etc. He's tweaked about writing his own chips and we wants to know if he can use the software & hardware that I'm using. Thanks in advance for any info.
Old Apr 20, 2001 | 03:54 PM
leirch's Avatar
As far as i know, yes the 93 LT1 is Speed Density. But i thought the computers were fully programmable(not requiring proms). I think you will probly need the LT1_edit software and what not to "tweak" his car. The only reason i know a little bit about this is because i was doing ALOT of research about the LT1's when i had my old RS.
Hope that helps. You may want to check out www.camaroz28.com or some other FBODY sites in general for ecm programming info.
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old Apr 20, 2001 | 07:28 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
The '93 F-body is the odd-ball since it was the only 4th-gen with SD and a removable PROM. I think they also still had the non-electronic 4L60 tranny since the 4L60E is controlled by the PCM (note that it's -Powertrain- Control Module). TunerCat might have a .tdf file for it, but I'm not sure. I think they might use a "bigger" chip than the 27C256, maybe the 27C512.
Greg Westphal
'87 IROC 305TPI/A4
Old Apr 20, 2001 | 07:38 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
278s (92-93) LT1 used the 27C256 also.
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
86camaroman201
Aug 19, 2015 04:52 PM
Fronzizzle
Aug 17, 2015 02:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
