Two quick questions...
Old Apr 21, 2001 | 05:41 PM
Mojo's Avatar
#1: Is the AT29C256 a direct plug in. Read: No emulators or special programming tricks required.
#2: Does anyone know where I can get the .ecu for the 870 ECM. I can't seem to find it at the gm_ecm website. I'd like to get as much information as possible out of my current chip, like the injector constant, etc from my current ECM. It's been pretty well dialed in, and I know that the person who programmed it had to fiddle with the constant to get it right, and I don't remember what the final result was.
Thanks!
408cid 1985 Corvette
http://www.mojosgarage.com
Old Apr 22, 2001 | 09:12 AM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Mojo, the 870 is a C3 ECM. It's slower and has a tiny memory compared to the later ECMs. I'm not sure the data that could be extracted would be of a lot of use when going to a P4 ECM.
Anyone else have an opinion on this?
Old Apr 22, 2001 | 04:01 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
#1) The AT29C256 is a direct plug 'n play chip for the 730 ECM only. You can make it work with other ECMs by loading the image into the appropriate Memory Area of the chip.
#2) I have no idea where you would find an ECU file for the 870 ECM. I would suggest posting a message to GMECM to see if anyone on there has one.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
