Spark table questions with ARAP bin part number 16134193 for the 89 Vette.
Old Apr 24, 2001 | 08:25 PM
Slow 89 Iroc's Avatar
I purchased ARAP bin part number 16134193 from a GM dealer. And as far as I know it is for the 89 Vette with aluminum heads. Now I am running it on an '89 L98 with stock iron heads with some success. But I have a question: What are the differences in the spark tables for the aluminum and iron heads? In a post made my Grumpy he states:
The AL heads make for quite a different animal, for timing (when using non oem cams). Also, can run alot less timing at WOT, and if you smooth out the chambers really make a difference.
Now since the ARAP for the Vette is running less timing at WOT what is happening?
Old Apr 25, 2001 | 07:25 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
I'm positive this was covered in the last week or 2, but the spark advance in the ARAP chip is quite a bit higher than the normal '89 350 chip for an F-body. They have more timing in most of the s.a. table from what I recall, definitely too much for iron heads and aftermarket aluminum heads. You could reduce your base timing a few degrees if you start encountering spark knock, or change the s.a. table itself.
Greg Westphal
'87 IROC 305TPI/A4
Old Apr 25, 2001 | 10:11 AM
Yelofvr's Avatar
I did a compare using tunerCat between a 1990 camaro 350 bin and a 1990 Vette(alum head) bin. Vette bin has a good bit more timing, up to 10 degrees more at 50kPa 2000 - 3000rpm. 6-7 degrees more at 75 kPa, 1000-3200rpm. At WOT, 100kPA it had between 2 and 3 deg more advance depending on rpm. The vette program gave me lots of part throttle mid rpm pinging, I took out about 10 deg. My motor is a 383 TPI w/ edel heads, 9.6:1 and NO EGR which makes a big difference at part throttle.
Dave Zelinka
Old Apr 25, 2001 | 12:58 PM
P J Moran's Avatar
Car: Used to be an '87 IROC
Engine: 5.7l TPI
Axle/Gears: 3:23?
I've looked at the spark table, too, and I think I'll have major detonation problems with that. I would like to look at stock '89 Camaro and Vette bins for comparison, if they're available. Are they on DIY-EFI? If so, what are they called? Where else might I get them?
'87 IROC 5.7l TPI - original owner!
[This message has been edited by P J Moran (edited April 25, 2001).]
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
twest2k2
Aug 24, 2015 11:26 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
armybyrd
Aug 10, 2015 09:23 PM
