Why does my chevy truck have a MAF and MAP?
Old Apr 30, 2001 | 04:08 PM
89vette's Avatar
I just noticed that my truck has a MAF and a MAP. Do the newer ECM's use both and for what reason?
Jason
89 Six Speed FX3 coupe
More Performance 396cid specs:
Callies 4340 crank 3.875 stroke
Lunati Pro-Mod 5.85" rods
SRP Pistons 14cc dish
Comp Cams Custom cam 550 lift 220/229 duration
10.8:1 compression
AFR 195 competition ported heads
Miniram and TPIS 1 3/4" headers
Old Apr 30, 2001 | 05:54 PM
Steves ZZ5's Avatar
I'm betting you have a newer 99 or above truck (CK) with a Vortec V8 right?
Just like the LS1's they use both a MAF and MAP for some reason, but I don't know why.
86 Trans Am WS6 Black with tinted windows, shaved door handles
ZZ4, Mini-ram, true duals, LT4 HotCam, AFR 195 heads.
***Too many other mods to mention***
"In the future, cities will become deserts,
roads will become battlefields, and the hope of mankind
will appear as a stranger"
The Road Warrior
Old Apr 30, 2001 | 06:14 PM
89vette's Avatar
Yes its a 2001 Chevy Silverado with the 5300 V8. Maybe the MAP is used for load where the old MAF like on my 89 uses LV8 which is a calculated value???
Jason
Old Apr 30, 2001 | 09:15 PM
TunedPort350's Avatar
Car: 88 GTA, 91 GTA, 92 T/A vert
Transmission: 6 speed & 700 r4's
Just a thought but are you sure there is a vaccuum line going to it? If not it might be just a baro. sensor... same identical sensor just when you don't put vaccuum to it and leave it open to atmosphere it reads barometric pressure.
Old Apr 30, 2001 | 10:10 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Actually, most of your OBDII engines have both, like the 5.0, 5.7 vortecs, the 3100, 3400, 3800, 4800-5300-6000-8100 vortec engines (genIII), etc... Even the later LT1 engines had both. And there is not a Baro sensor anymore. The PCM uses the MAP sensor to take a "baro" reading when the key is on, then is used as a MAP sensor once the engine starts.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
Old Apr 30, 2001 | 11:16 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by 89vette:
Jason
</font>
Each have their own strong points. Done right, the MAF will supply a slightly more accurate steady state reading then the MAP. The intake tract on a MAF does some signal dampening, and prevents some reversion errors. The MAP allows for much better metering suring sudden transistions. the MAP is always prone to some (small with stock cams) reversion errors
Amillionoh7
Sep 11, 2015 11:36 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
