Where to start with a MAF prom for Lingenfelter 74216cam
Old Jul 30, 2006 | 10:15 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
My cam is Lingenfelters #74216 specs are 213/219 duration @ .050 .493"/.502". I'm running an 89 style MAF ecm and I am curious to what I'll need tune for this cam. I know I need to set the minimum idle to 750 and get full spark advance in a little sooner but will I have to modify the fueling tables? The motor will have ported stock heads on it, long tube headers, and close to stock compression ratio. Thanks in advance everyone.
Old Jul 30, 2006 | 11:18 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The MAF is pretty much independant of the engines configuration (well, almost). Shouldnt need to do much to the MAF tables. Depending on the cam, changing the filtering can help smooth out the motor at low loads, but theres only one MAF filtering constant for all flows in the stock ecms, so its a balance between filtering the signal and still having good response. If your using differnet injectors, or fuel pressures, then the injector constant will have to be adjusted. But thats about it.
Old Aug 1, 2006 | 07:24 PM
Thanks for your response, that's what I was hoping to hear.
Steven 86IROC-Z
May 24, 2026 04:52 AM
Glowsock
Jul 24, 2025 03:15 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
perZ
Aug 15, 2015 01:17 PM
