give me 10 items to address in $55 EBL
Old Jul 31, 2006 | 04:31 PM
Ronny's Avatar
moving my tune into the above. day one of EBL with prominator. we B hy tech. currently a 7747- $42- 2732.
is there an easy way to flip my .bin over? RRob provided for me a stock $55.bin. i think a auto trans. other than cut/paste is there a simple way?
much of my tune will vary from a stock application. see sig. what will i need to watch for in $55 stock bin? what might i overlook?
Old Aug 1, 2006 | 06:58 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Things to set right off: displacement value, the BPC table (if running a non-vac adjusted regulator make all entries the same), initial SA, SA tables, the TCC/Stick option bit, disable highway cruise (for tuning), can set the rev-limiters.
For the VE I've used Excel to convert them. Need to get creative as the 3D table needs to be pivoted. May be easiest to calc the 90-100 KPa values and plug those in. Then spot check some other areas. If close then let the VE Learn take care of it.
The SA tables are much the same way. If you have good timing values move those over.
Then fire it up, enable data logging, and see how it runs. Once up to temperature the VE Learn can be used. Once it is running decent (closed loop will help), drive it around some. Do a VE Learn, tweak anything that may need it, then drive it some more.
RBob.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
e3pres
Sep 9, 2015 01:51 PM
Fronzizzle
Sep 8, 2015 12:10 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
85Special
Sep 3, 2015 04:21 PM
