Converting to 730
Old May 3, 2001 | 02:26 PM
87IROC350's Avatar
Engine: 5.7
Converting to 730
Anyone know where I can obtain the correct crimp pins that Mike Davis used to attached the wires to the donor connector.
I checked Radio Shack and they had nothing even close. If someone has a part number and place to obtain them through I would like to just order them through mail. If not I might try a local electronics shop this weekend.
Old May 3, 2001 | 03:03 PM
leirch's Avatar
You don't NEED the crimp connectors, check out my page at www.geocities.com/leirch_/
i think pictures 29 is of my "harness" and computer for the 730 swap. Now granted, the connectors would have been NICE, i got by with a bare ecm header and wire and solder..
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old May 3, 2001 | 07:47 PM
Brent's Avatar
They are listed here:
http://www.diy-efi.org/gmecm/faq/gm_connectors.html
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
okfoz
Oct 13, 2015 02:19 PM
loud91rs
Oct 5, 2015 10:05 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
