Pocket programmer update for windows
Old May 4, 2001 | 09:50 AM
87IROC350's Avatar
Engine: 5.7
I just called intronics (makes the pocket programmer)to followup if they had a fix for the 29C256 programming issues in windows for the flash chips. They stated they updated the Windows programmer software to v1.10 and supposedly this will solve the timing problems when programming the flash chips. I'm gonna try it later this evening and see if it works.
Has anybody tried the update version and had luck?
87 Iroc 5.7, AFR190, SLP Cam(218/224), SLP 1 5/8 headers & cat back, Random CAT, SLP Runners, 48mm TB, custom chip(by me), Vigilante & Probuilt trans.
Old May 4, 2001 | 01:39 PM
87IROC350's Avatar
Engine: 5.7
Hey gang I tried the update and it programmed the first time no problem and then tried 5 more times and the other 5 times it would not program. Oh well! I was being hopeful. (FYI-The release date on the update is April 14)
Old May 4, 2001 | 01:42 PM
CanadianBeast's Avatar
I was just curious but are you using the 29c256 in your 165 ecm, or did you switch to the 730? If you are using it in your 165 could you explain the process you go through to make it work. I'm sick of this UV eraser.
Old May 4, 2001 | 01:51 PM
87IROC350's Avatar
Engine: 5.7
See my other post.
[This message has been edited by 87IROC350 (edited May 04, 2001).]
Fireslash
Apr 11, 2016 06:43 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
86IROC112
Nov 7, 2015 06:50 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
kkirch15
Sep 30, 2015 04:44 PM
