Tuner cat-knock question?
Old May 9, 2001 | 05:11 PM
precision350's Avatar
What exactly does the "knock attack rate" do? For example: 1200 RPM / .18 degree/msec. Would this mean that at 1200 RPM if the knock sensor senses vibration it will retard the timing .18 degrees per millisecond? Or am I not on the right track?
Old May 10, 2001 | 06:58 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
You're on the money. FWIW, the knock recovery rate is in %/second, which means that the amount of timing removed is added back at X% per second. I have mine set at 100, 100, 150, 200, and 200. These are way higher than the stock values since it took too long for the computer to add the timing back in, which killed power and my 1/4-mile times.
Greg Westphal
'87 IROC 305TPI/A4
Old May 10, 2001 | 08:26 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Also, in trying to control knock retard, you can play with the Max Knock Retard vs MAP or RPM.
Old May 10, 2001 | 04:19 PM
Thanks guys. That helps out a lot.
Old May 10, 2001 | 04:25 PM
Now that I understand what it does, would I want to increase or decrease the values?
Old May 11, 2001 | 11:45 AM
Engine: 385 HSR
I left my knock attack rates alone for the most part. I figured that if I got some real knock, I'd want the computer to pull out enough timing to "extinguish" it, then add the timing back in really fast with the high values in the knock recovery rate table.
Greg Westphal
'87 IROC 305TPI/A4
Fast355
Dec 2, 2016 06:33 PM
bryanwood74
Sep 24, 2015 09:50 PM
355tpipickup
Aug 19, 2015 10:02 PM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 11, 2015 10:22 AM
