Pulse widths higher at the track??
Old May 10, 2001 | 12:47 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I went to the track Saturday, after getting my car dyno tuned with custom chips a couple weeks ago. I had the injector pulse widths down in the low 9ms range. At the track, they were up in the 10ms range! What gives? It was cooler at the dyno than the track.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old May 10, 2001 | 01:04 AM
james_fearn's Avatar
what were your times last weekend with your hotcam?
James
Old May 10, 2001 | 08:23 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
It may have been cooler at the dyno, but what were your MAT temps? I find just sitting in one spot also causes my relocated MAT temp to rise. Also, elevation has an effect too.
Lastly, what was your coolant temp at both?
Old May 10, 2001 | 02:50 PM
Kevin91Z's Avatar
James, last weekend at Carlsbad I got a new best time, in my sig.
This weekend at Famoso I couldnt get better than 13.4 @ 105.50, but I only got four runs, 2 practice and 2 eliminations.
Glenn, at the dyno the MAT temp was 22* C, and the coolant temp was 76-78* C.
At the track the coolant was 84-88* C, and the MAT was 32-34* C.
I have the runs if you want to look at them.
Old May 10, 2001 | 09:15 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Glenn covered everything that I can think of ...
1) IAT Temp
2) Coolant Temp
3) Altitude
All the evidence suggests that you should have seen the opposite. As IAT goes UP the Multiplier goes down in order to use less fuel. As coolant temp goes UP, the PE table value goes down in order to use less fuel. I guess the remaining question is altitude. However, along with this question I would pose the following: Plot a graph of RPM vs Pulse Width for each diacom run. Compare the pulse width to each RPM reading. To the graphs look similar except for amplitude?? The highest pulse width for each run was at what RPM?
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
Moderator: PROM board at thirdgen.org
Old May 13, 2001 | 10:16 PM
Kevin91Z's Avatar
I uploaded the Diacom runs to my webpage, they're at http://24.1.139.249/dyno/
They're the ones that start with F. I was using the Dyno24.bin PROM.
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
Old May 15, 2001 | 12:32 AM
Kevin91Z's Avatar
Ok, lets try this out. If it makes sense, I know Tim and Glenn will say "I told you so"
I still have my chip with the WOT mods made to the 100 KPa region only. At the dyno I was seeing 100-101 KPa on Diacom, but at the track I was seeing 98-99 KPa. Since I made the changes to the 100KPa region only, the 95 KPa region is still higher values. So if the computer averages them, the high values at 95 KPa with the lower values at 100 KPa would make the pulse widths higher than what I saw on the dyno, right?
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Hal87
Exterior Parts Wanted
Nov 8, 2015 03:40 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
jaridjohn
Oct 5, 2015 07:01 AM
