Quick question on 29C256 prom
Old May 18, 2001 | 10:13 AM
89vette's Avatar
There is a little arrow on one end. Is this the end that points towards the outside of the MEMCAL?
Jason
Old May 18, 2001 | 10:31 AM
leirch's Avatar
Look for the little cut out, the semi-circle cutout , that goes to the outside of the memcal.
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
89vette's Avatar
Got it! Thanks!
Jason
89 Six Speed FX3 coupe
More Performance 396cid specs:
Callies 4340 crank 3.875 stroke
Lunati Pro-Mod 5.85" rods
SRP Pistons 14cc dish
Comp Cams Custom cam 550 lift 220/229 duration
10.8:1 compression
AFR 195 competition ported heads
Miniram and TPIS 1 3/4" headers
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
