closed loop idle BLM 128, Integrator 147+ very lean?
Old May 18, 2001 | 08:25 AM
blak92!'s Avatar
too lean? O2 values are between 100-200 mv also. Timing will not advance past 25 degrees with slight load in neutral.
A ZZ4 cam, extruded MAF TPI with TF 23 heads. 19lb injectors. This truck can idle but any load (in gear only) causes some backfiring. I know that the fuel delivery with a stock 305 chip and 19lb injectors is not nearly enough fuel delivery.
Base timing is set at 8 degrees and idle at 750 (very smooth idle). Any input?
Hybrid Black 5.7L 5 Speed
'95 Competition Yellow Corvette Coupe ZF6
[This message has been edited by blak92! (edited May 18, 2001).]
Old May 19, 2001 | 09:55 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by blak92!:
</font>
You've answered your own guestions.
Base timing at 8 is fine.
Eric2ndGen
Nov 5, 2015 01:51 PM
bamaboy0323
Sep 3, 2015 06:07 AM
CORV3TT3
Aug 23, 2015 11:26 AM
beast94
Aug 20, 2015 06:44 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
