Is there any free scan tools out for the labtop other than freescan....
Somebody tell me if I'm wrong but I don't think freescan will work for an 86 camaro will it....
It shows 92 up...
Is there any thing else out there.
It shows 92 up...
<font face="Verdana, Arial" size="2">Originally posted by leirch:
Last i checked, free scan worked for an 89vette(maf tpi).</font>
Can anybody back me up on this one?
It should work, i wouldn't see why not. I would personally take your 86chip out, get some form of an 89 code chip, unplug your cold start and disable the vats in the 89chip and try it. Couldn't hurt.
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
My 'ware will work on 86-92 TPI, MAF or SD, no problem. Pop that cold injector connector loose and run you some ARAP code!
<font face="Verdana, Arial" size="2">Originally posted by Craig Moates:
My 'ware will work on 86-92 TPI, MAF or SD, no problem. Pop that cold injector connector loose and run you some ARAP code!</font>
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
FueledSoul
Sep 26, 2015 12:00 PM
