Hook My Laptop To My ALDL
Can I make a cable to hook up my laptop COM1 port to my ALDL port on my 1986 IROC-Z? Can someone direct me to a good site that perhaps shows step-by-step how to do it?
I just made this one the other day. I'll be trying it out later this week hopefully.
http://pweb.de.uu.net/pr-meyer.h/aldl.htm
This is essentially the unit that i am using as well. you are going to need a comm program. I would suggest that if they have a version for your setup that the DataMaster is a really good one. check this out:
http://www.mindspring.com/~amattei/dss.htm Andrew has a lot of good info @ his site & if you so desire he has kits that you can buy to solder your own or you can just by the enitire thing yourself. He also has the best deals on the data master, that i have found. I have dont both (i gave one to a friend).
BW
Bobalos
aka Bob W.
www.r71camaro.homestead.com
r71chevy@earthlink.net
BW
Bobalos
aka Bob W.
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Use my software, it's free and it does the job you need.
http://members.tripod.com/moatesenhe...mecm/index.htm
Assuming he has TPI...
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
I had my wife by me something @ a yard sale that plugged into a Cig lighter (does not matter what). Cut off the cord.
MAKE SURE, that you plug it into the car & check to see which one is +12 & which one is ground BEFORE you hook it to your circuit, you dont want to putting the power backwards across the regulator.
BW
Bobalos
aka Bob W.
BW
Bobalos
aka Bob W.
Z28/ZR1
Oct 23, 2015 01:04 PM
