Fuel Pressure - how to check
Old Aug 7, 2006 | 05:29 PM
twadam's Avatar
I've read conflicting entries on what the fuel pressure should be and how to check it... can anyone enlighten me on this.
'87 TPI 5.7, 24# injectors, TPIS intake, Top Proline Heads
I've read that fuel pressure should be anywhere from 38 - 46 lbs. I also keep reading about 43.5 being stock (something about "3 bars"). Should I be higher or lower pressure from stock with the bigger injectors ?
Also do you check the pressure with the car running with it shut off (key on), with or without the vaccum line connected to the regulator ?
I'm confused ...
Old Aug 7, 2006 | 08:15 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
The GM shop manual says the fuel pressure should be check with the key on engine off and should be at anywhere between 41 - 47 psi. Since most injectors are rated at 43.5. If you have a AFR, 43.5 psi should be your starting point. I run 45 - 47 psi on mine and have good performance. Be aware that when you change fuel pressure you also change the flow rate of the injector. There is a special formula to calculate your new flow rate. I cant find it right now but its something like New flow rate = Square root of (new pressure/old pressure) x old flow rate. This is important when doing your own prom tuning.
Old Aug 7, 2006 | 09:05 PM
twadam's Avatar
Anyone else ?
Thanks for the info Derek !
Anyone else running the factory specs ... and is this how everyone else is checking there fuel pressure ?
That is interesting about the formula for flow rate ... it you find it, would you mind posting it ...
Old Aug 11, 2006 | 09:34 AM
twadam's Avatar
No one else ?
I'm assuming since no one else has posted that everyone agrees with Derek's process for checking the pressure ? No offense to Derek, I just like to get multiple opinions.
I just want to know for sure ... cuz' my dad has been checking it with the motor running. I don't want to have to re-tune this car after we find out we set the pressure wrong.
Old Aug 11, 2006 | 10:17 AM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
If the motor is running, manifold vacuum is altering the pressure (at idle, for instance, the pressure typically sits at 37-39 PSI, depending on your settings). Rev the engine and you'll see what I mean.
Derek is correct. Key on, engine off. Make sure the ECM has primed the pump. It might be worth keying off for 20 seconds and then on a second time to re-prime.
With that said, this is the DIY-PROM forum. Your question might see more responses in the General Engine forum.
Old Aug 11, 2006 | 01:35 PM
twadam's Avatar
Thanks Mangus
I will try to post in the proper place next time. Now that I know the proper way to check this, it's off to the garage ... thanks!
92camaroJoe
Jul 29, 2023 07:57 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
