yes,i know this is a dumb question but i can only get it to run from disk,i've followed the manual and re booted into dos and then ran the a:hdsetup command,it seems to load the program (you can exit and then reenter)but then when you go to windows and then restart in dos it is gone? anyone know whats up?i also tryed to copy the disk as suggested and it will not copy.tryed the dos command diskcopy and the windows explorer copy(works but data is corrupted.
this is a registered copy and i'm following the instructions in rindas manual just appaers that i dont know how to get dos programs to work?
please help me so i can capture some data and start burning chips.
thanks
pete
ps i'm using a hp 450mhz pent 3 computer with win 98
[This message has been edited by blowen90ta (edited May 23, 2001).]
thanks
pete
Quote:
<font face="Verdana, Arial" size="2">Originally posted by blowen90ta:
thanks
pete
[This message has been edited by blowen90ta (edited May 23, 2001).]</font>
Diacom is not compatible with all machines, especially some of the faster ones. If you hunt around the syty list somewhere is a list of machines that are know not to be able to handle diacom.<font face="Verdana, Arial" size="2">Originally posted by blowen90ta:
thanks
pete
All I ever recall doing is coping the files to the HDD. No install.
Then just run it from explorer.
