ok to run modded motor with stock chip???
Old May 22, 2001 | 02:08 PM
NOSFEDGTA's Avatar
I have a built 383 with all the goodies and was wondering. Is it ok to drive on my stock chip while I figuire out my DFI??? I just do not want to do any damage to my new motor. It ahs 30 lb inj its a mass air car and 58mm t/b. any help would be great...
Old May 22, 2001 | 03:04 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
The biggest problem with your MAF 383 will be it will be running too rich due to those 30 lb injectors.
Displacement is not an issue with a MAF car as it bases everything on air flow, in fact, there is no provision in the MAF eprom to define the displacement of the engine. I have successfully installed the ARAP BIN that is intended for a 350 in a 305 and the only change I had to make (other than a few other tweaks) was for the smaller injectors. When adjusted for the smaller injectors, the 305 ran damn near 128/128 perfect.
With a big mouse, the 255 gm/sec may become a limitation within a normal operating range. It really depends on how much air it needs to consume, and where.
Old May 22, 2001 | 03:18 PM
NOSFEDGTA's Avatar
So I take it I should not drive it then?? or is it ok? I am new at learning all this stuff. As for the parameters and changes to make on my Haltech, any computer tweaks I am still new at. I am used to just buying a chip.
Old May 22, 2001 | 04:01 PM
leirch's Avatar
I would do some reading of the Prom burning introduction article and then do some more reading of the article, and then maybe even go over it a third time.
See get the back stuff needed to make your own chips, if you could get enough to change just the injector constant and maybe a few other small things, you could "probly" drive the engine till it was broke in.
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old May 28, 2001 | 10:41 PM
FormulaGod's Avatar
My 355 tpi (fully modded, heads cam, everything) was put it in in place of my stock 305 tpi.
The chip is even stock. I have like 5k on the engine and its running fine although i do realize that i need to burn a new chip for it to see my real gains.
"Restore decency in America. Ban rice!!"
Moderator at www.Lastgen.com check us out!!
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
italiano67
Dec 11, 2016 09:21 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
