setting base timing?
Old May 29, 2001 | 08:35 AM
prscarf's Avatar
What is the correct method of setting the base timing to 0deg:
Unplug the computer control spark advance
Rotate the distributer to 0 deg with the engine running, using a timing light
Replug the computer control spark advance.
Now the eprom spark advance is equal to a timing light reading.
I am correct with this?
Old May 29, 2001 | 08:37 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Yes, you need to unplug the tan wire (ESC) to set the timing.
Base timing on most TPI cars is 6* BTDC however.
Old May 29, 2001 | 08:39 AM
prscarf's Avatar
mine is 383tbi.
Old May 29, 2001 | 08:48 AM
Car: Death Mobile
Engine: 666 c.i.
LO3 (tbi 305) is 0* base. But, you have control over this if you are burning your own eprom. You just have to make sure that the base timing set in the eprom agrees to the actual setting.
I have a buddy that we just installed the ARAP BIN in his 1LE car. He had set the base timing to 10* BTDC prior to being able to burn his eprom. When we installed the ARAP BIN, he/we were too lazy to change the base timing, so we just set the Base Timing in his eprom to match the 10* BTDC setting. Worked fine, though once he gets home he is going to set everything back to 6* (unless he doesn't).
Old May 29, 2001 | 08:51 AM
prscarf's Avatar
[QUOTE]Originally posted by Glenn91L98GTA:
[B]LO3 (tbi 305) is 0* base. But, you have control over this if you are burning your own eprom. You just have to make sure that the base timing set in the eprom agrees to the actual setting.
i am using the stock 350 bin spark table setting the 0 base is alright?
Old May 29, 2001 | 08:56 AM
Car: Death Mobile
Engine: 666 c.i.
I cannot answer that as my 1991 GM shop manual for my Firebird only lists the LO3 305 TBI. I can only assume that the 350 TBI is the same.
Old May 29, 2001 | 09:00 AM
prscarf's Avatar
i am burning my own chips, i just want the chip spark table to be true to what the engine is at without having to add advance because my base is greater than 0. not sure if my engine base is oem @0 or 6deg with a stock spark table? 91 350 4x4 truck
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Andrew6.688
Dec 13, 2015 10:59 AM
