MAP sensor on MAF cars, what's it do?
Old Jun 5, 2001 | 09:35 PM
Greenshamrock77's Avatar
I've noticed that MAF cars generally have a MAP sensor, including my dad's GN. What function does this serve to the ECM? Is is to sense vacuum for the EGR? When I look at the wire diagram, I do not see it. However, I see an "EGR VACUUM SENSOR" pin "C15". Is that the MAP sensor? This would be on a "165" ECM.
82' Z-28. 327" w/ flat tops. 216/228/112LS. Pocket ported 041 heads 1.94/1.50 SS valves. World Class T-5 from a 91'. Best run? Runs with 2001 vette to 150mph! Soon to be converted over to TPI w/ supercharger.
Old Jun 5, 2001 | 09:41 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by Greenshamrock77:
</font>
The GNs and TTAs use the sensor for the indicator lights for boost on the dash, they are not tied into the ecm.
The EGR vas switch is just a pressure switch to make sure there is vac present at the egr controller.
On some PCMS (like the LT1 and LS1s) they use both, the MAP is kinda a double check on tht MAF, and maybe used for sudden transistions, and the MAF for more steady state.
specialized
Jun 18, 2022 09:26 AM
9192camaro
16
Feb 3, 2019 12:21 AM
NBrehm
Aug 25, 2015 11:49 PM
squiggy2
Aug 9, 2015 09:30 PM
