Here goes nothing, but need help first!!
Old Jun 17, 2001 | 09:19 PM
Z28Man's Avatar
Well I successfully burned my first prom, I burned ARAP coded prom for my 88 Camaro. I disabled VATS and EGR. My question is should I use my 1988 Memcal with 1989 code? Are the VATS Memcals different? I am new to this so I don't know if the 88 and 89 memcals are that much different. Thanks!
Old Jun 17, 2001 | 09:40 PM
hectorsn's Avatar
Car: 78 Regal
Engine: 82 FBod LG4 305, 730 ECM
Transmission: M20
Axle/Gears: 4.10
For all intents and purposes all you've done is alter your prom regardless of the fact that the bin you put in is a factory program, except for the egr and vats delete. The memcal is physically the same, the vats is in the program.
edit: forgot to mention that the limp mode (netres, other memcal devices or whatever you wish to call them), worked fine before the ARAP bin and should work fine again.
[This message has been edited by hectorsn (edited June 17, 2001).]
