Prominator-EBL won't load a bin?
Old Aug 21, 2006 | 09:23 AM
Ronny's Avatar
first use of above. need some help.
here's what i did.
1. booted laptop.
2. loaded prominator software
3.it says connect P to PC which i assumed is connect to parrallel port. seems if already connected will not recognize the P? don't understand why?
apply power. i turned on ign.
5. located .bin in my documents. loaded RonEBL.bin which is EBL .bin with my modifications.
6. all went well cept when i crank starter nothing.
tried again and same story. after multiple attemps i rec'd some error meassages and interior lights flicker as door open
a.runtime error.
b.failed address (0) verify error
c.target busy
also i tried to get Whats Up display to show TPS data with ign on.
first attempt successful. both TPS data flowed and MAP showed like 96 so i guess commnications with ECM. tried again later and WP says cannot locate configueration file ? no longer can get WP to work.
com port on #4 in laptop as is WP. USB with radio shack adapter to serial.
what am i missing? what steps did i skip?
Old Aug 21, 2006 | 09:38 AM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
That R/S USB adapter sucks.
Old Aug 21, 2006 | 09:41 AM
Ronny's Avatar
worked OK for WinALDL? same with Innovate LM1.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
jrdturbo
Mar 31, 2016 02:58 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
efiguy
Sep 27, 2015 01:30 PM
Mdenz3
Sep 17, 2015 08:36 AM
