cable for craigs software
Old Jun 22, 2001 | 01:16 PM
Mo's Avatar
Mo
I think I pretty much have this figured out except for one piece. How do I connect it to the aldl, like what piece do i need that will plug in to it, and where can i get it?
90 IROC 5.7l (L98)
ram air, K&N's, air foil,Flows
LIKE A ROC
http://members.nbci.com/IrocZgarage/home.htm
Old Jun 22, 2001 | 05:45 PM
AlexJH's Avatar
Engine: 5.7L V8
http://www.andywhittaker.com/ecu/aldl_hardware.htm
has a simple one.
Old Jun 24, 2001 | 04:27 PM
89GTA5spd's Avatar
The two transistor one that there is a link to above works fine on my 89. Just remember a 10K resistor between port A & B and to get 12V and ground from the car. The data pin is 'M' in our cars.. so all you have is a 10K resist between a & b and one wire into the 'M' port and your two transistor circuit. very easy.
Old Jun 24, 2001 | 10:01 PM
Mo's Avatar
Mo
ok, so all you do is stick wires into the aldl, you don't actually need a connector to plug into it?
90 IROC 5.7l (L98)
LIKE A ROC
Old Jun 25, 2001 | 03:28 AM
89GTA5spd's Avatar
yeah, no connector required. A resistor can just be bent and stuck in the A & B terminals, for the "M" terminal just use something stiff enough to stay connected, a solid core wire will probably work fine or you could find a electrical connector that would fit in there i'm sure.
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
