a newbe quandary
Old Jul 2, 2001 | 03:51 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
a newbe quandary
Since the O2 sensor does not opperate at WOT, how do you know if you are too lean or rich in WOT???
John
Old Jul 2, 2001 | 04:05 PM
kevinc's Avatar
Car: 1982 Z28
The O2 sensor operates at WOT.
The ECM doesn't run in Closed Loop mode, so it's not capturing input from the sensor and adjusting fuel delivery based on it.
I tune my Power Enrichment vs. RPM table ('165 ARAP code) using O2 sensor input. Not terribly accurate compared to a wide-band sensor but better than the carb guys have.
-Kevin
1982 Z-28
See http://www.mycar.net/mafb/registry/detail.cfm?id=276 for details
Old Jul 2, 2001 | 04:08 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
<font face="Verdana, Arial" size="2">Originally posted by kevinc:
-Kevin
</font>
If you rely on the O2 sensor, don't be surprised when one of those "old fashion carb guys" beat you using "old fashion tuning tricks". There is a LOT to be said for the "old methods".
I think even if you have a WB sensor, you should still get as MUCH information as possible. I really don't believe in "tuning by number" alone. It can lead to false conclusions and incorrect tuning.
Old Jul 2, 2001 | 04:31 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by okfoz:
John
</font>
The only accurate way of **seeing** where you are at WOT is by reading the plugs.
You have to measure performance, and see what the engine wants, and then give it that. This ol blanket of 38d timing thing is for the birds, or uninformed.
You have to actually test to find out what the engine wants, period
bluechevy194
Mar 19, 2006 07:59 PM
BOSS 357
Nov 2, 2005 11:04 AM
IROC-Turbo
Carburetors
Apr 6, 2005 05:31 PM
ajbutowicz
Nov 13, 2004 02:46 AM
okfoz
Jun 13, 2001 10:44 PM
