couldnt think of anywhere else for this
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
how hard would it be to convince somebody to make something that read off of the aldl and sent to a lcd display that would show your blm and integrator #'s.
what are your thoughts on this, it would be the best a/f ratio gauge available.
actually i think it would be nice to set up console gauge cluster above the radio that would read a lot more, like tps voltage, map, would this be impossible because of the slow rate of the aldl?
92 305cu tbi. 8746 ecu. stock.
Dale Earnhardt, #3 has crossed the finish line with a victory.
IM: snflupigus | ICQ: 96787192
Snflupigus.com
Open Element Tech Article
ENGINE SPECS:
Stock Rating: 170bhp & 255ft-lbs
305 TBI,Open Element,K&N 14x3,Hypertech Stage I,454 GM TBI
Now Rating: A Little More
STEREO SPECS:
JVC Kalmeleon kdlx3,Infinity Kappa 2way 6x9's,PPI 4x6 Coaxials,PPI PC2400 AMP @ 2ohm
DEI Studio 12" 4ohm DVC,Custom Box:Exactly 1 Cubic Foot
Snflupigus.com
ENGINE SPECS:
STEREO SPECS:
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by snflupigus:
actually i think it would be nice to set up console gauge cluster above the radio that would read a lot more, like tps voltage, map, would this be impossible because of the slow rate of the aldl?</font>
Between this and the Translator ya'll should get ahold of Bailey Eng., and ask what kinda min order he would need to crank up a version for the 3rd gen cars.
His address is at the gnttype.org area.
Beleive it or not makes chip burning alot easier, when you have all the tools available. You can't data logg with it, but it's a whole lot cheaper then Diacom Plus.
maybe i should just buy the cherry looking red gnx down the street. LOL. naa, ill check with that guy though. thanks.
i figure, im a smart guy, im a cs major, and i know i could really get this chip burning stuff down really well if i just took some time to learn it.
i just wish i could get my programming teacher into it. the guy is a freaking genious, he just got done with a contract for the gov encrypting gps hardware for some satalites going up soon.
the only auto stuff hes done is program a high tech alignment machine. wish he was a car guy
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
hmph, I was thinkin about doing something like this in the front of my overhead console. There are those almost useless dials & numbers thingies I was thinking of making into a High intensity LED display of some sort. Since all I need is a few wires to go up there, All I would need is a small enough computer to convert the info...hmmmm
John
John
