88 PE SA correction for AFR
Old Aug 29, 2006 | 06:03 PM
AtomicTruck's Avatar
Car: Pro Stadium Tough Truck
Engine: Buick V6 272 cu in
Transmission: TH350
Axle/Gears: Broken most of the time
how can it correct an afr of 9.9 using a narrow O2?
I have a very unique programing need an I'm trying to find the best and easiest starting point. I worked on 8D for a long time... it seems to be VERY well supported and documented but... I don't really like ALL the extra timing tables and other stuff I won't use for my racing application.
So now I'm taking a close look at 88. Thanks for the help.
Old Aug 29, 2006 | 07:55 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The 9.9 AFR is the commanded AFR, not the O2 sensor feed back value.
RBob.
Old Aug 30, 2006 | 10:37 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Set your PE values to be somewhere between 15% and 20% (and make sure the VE is right). Don't know how to do this in 88, though, never looked at it.
Old Aug 30, 2006 | 10:39 PM
Transmission: TH350
skinny z
Carburetors
Sep 29, 2015 11:25 PM
CatmanFS
Sep 19, 2015 09:00 AM
355tpipickup
Sep 13, 2015 11:35 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
89fast5oh
Sep 8, 2015 09:55 AM
