EBL-Learn VE Q?
Old Aug 30, 2006 | 02:57 PM
Ronny's Avatar
EBL-Learn VE Q?
believe all is functional. Prominator is working well. TP still has labeling issues for tables. mark is investigating. appears TP appears OK without tables labeled.
Q on whatsup.
1. i understand VE-L requires a saved datalog to learn off of. first one i saved last night and ran the datalog this AM on kitchen table. i am at office so dont have notes. i used high speed to take a 15 minute log down to 3 minues or so. i believe i ended up creating a new bin as a result. followed the directions. i compared VE data and it appears some changes resulted. i expected more changes?
2. apparently i could have set up to create a new bin off datalog w/o needed to playback datalog? is this correct?. if so then i just download new bin with Prominator at end of datalog session without playback. i believe it is called ronbin_NEW?
3. the BLM's are moving from 172 downward. but ever so slow. is this to be expected? i used the ebl.bin and added 20% to base values in VE1 table(<2000 rpms) after first log at idle and just off idle cruising at 10 MPH in 1st and 2nd gear(of 5). as stated 2nd and 3rd datalog moved BLM from 172 to 150 to 140.
