During cruising the BLM/INT are frozen and the engines is running lean.
Old Jan 11, 2008 | 08:26 AM
bataradena's Avatar
Car: K1500
Engine: 7.4L
Axle/Gears: 4.10:1
Maybe this is normal but I’m not sure. I’m using EBL-Learn and just started tuning my slightly modified (RV Cam) TBI-7.4L engine. I noticed during my drive home the ECU is making adjustment to the BLM/INT to achieve the correct fuel air mixture and everything is doing just fine, but then I noticed during mostly freeway cursing the BLM-135/INT-128 seem to be frozen with no movement and the engine is running very lean, about 50MV output from the O2 sensor. My question is, is this A “Lean Cruise” operation of the ECU or is there something wrong? If this is normal operation can I change in the BIN to stop this type of ECU behavior. Byron T
Old Jan 11, 2008 | 09:53 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: During cruising the BLM/INT are frozen and the engines is running lean.
Highway mode lean cruise, improves the fuel consumption quite a bit. To disable it set the MPH to enter highway mode to 245 MPH (HiWy - Min MPH).
RBob.
Old Jan 11, 2008 | 10:17 AM
bataradena's Avatar
Car: K1500
Engine: 7.4L
Axle/Gears: 4.10:1
Thanks again.
Byron
bradleydeanuhl
Aug 12, 2015 11:48 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
Bull86
Aug 10, 2015 05:43 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
