ATTN: GLENN, Can you or anyone tell me if this ECM is another type of the 7730 ECM's?
Old Jul 11, 2001 | 10:54 AM
88SS6SPEED's Avatar
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
I got a harness section from a 91 OLDS Calias. It has the exact same 24 pin BLACK plug, 32 pin BLACK plug, and a 32 pin YELLOW plug, the ECM S/N is 01228706. I can't find a cross reference for this ECM, any help would be great.
88 Monte SS 355 TPI/LT-4 HOT CAM/AFR Hydra-rev/ T-56 6-Speed/1-3/4" full length headers/3" X-PIPE assembly/ 8.5" G-80 rear with 3.73 gears.
http://community.webshots.com/user/ssynergy
www.y-t-g.com/88monte
Old Jul 11, 2001 | 11:07 AM
Steves ZZ5's Avatar
88SS,
Delete the zero, and you're looking at a 1228706, compatible with a 16198266 ECM. The only thing similar is that it uses the same 27C256 PROM as some of our V-8's, but that's about it.
This ECM was used in an 89-93 3.3 litre V-6 LG7.
http://www.cruzers.com/~ludis/p4xref.html
86 Trans Am WS6 Black with tinted windows, ZZ4, Mini-ram, true duals, LT4 HotCam, AFR 195 heads.
***Too many other mods to mention***
"In the future, cities will become deserts,
roads will become battlefields, and the hope of mankind
will appear as a stranger"
The Road Warrior
[This message has been edited by Steves ZZ5 (edited July 11, 2001).]
Old Jul 11, 2001 | 11:39 AM
leirch's Avatar
My name isn't Glenn, but go to the technical articles on this site and look for the ecm interchange article. It will tell you everything that you need to know.
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 SR Cam, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
Old Jul 11, 2001 | 01:17 PM
88SS6SPEED's Avatar
Car: 88 Monte SS
Thanks guys, I will just desolder the pin headers from this ECM, and use them for a later project.
Old Jul 11, 2001 | 02:56 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
As mentioned above, that is for the 3.3 PFI V6s.
You need an ecm from a 3.1 V6 PFI (engine code "T") from a non-Fbody or non-Wbody. Check the 4th digit to see what type of body it is. J bodies (Cavaliers) work just dandy from 90-93, along with Corsicas, Berrettas etc. The key is Engine type "T" 3.1 V6 with non-F or W-body from the early 90s.
That ECM MIGHT work, but there is very little information on it. It is probably a derivative from a 730, but you don't know what "drivers" are missing or added so it is a little bit more of a DIY project...especially considering there are a TON of early 90 Cavaliers lying around.
Glad to see you are now getting into PROM Burning, Ashley.
InfernalVortex
Apr 20, 2021 11:31 AM
MrPackstin
Oct 25, 2017 08:09 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Briandrex
Oct 5, 2015 06:20 AM
bjpotter
Oct 4, 2015 07:48 PM
