For anyone familiar with an '86 TPI harness.
Old Jul 8, 2001 | 10:06 AM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
Right now I am in the middle of swapping out my carb for TPI and have a few qusetions.
First, there are 2 heavy wires that run down the driver side frame rail and go to the battery (Pontiac setup). From the diagrams I have it looks like they both get positive power, am I right?
Second, there are 2 connectors that I can not identify, one looks like it would go to the A/C canister (different connector from what I have) and the other one comes out by the master cylinder. The second one has 2 wires in it with a square shaped plug, any ideas what it does!!?
'86 TA, T-tops, T-5, 3.73, 4 wheel disks 350, compucam 2040, performer intake,SLP Headers, 3" race magnum muffler, 1.6 Comp rockers, Ripper shifter, perf. friction pads, Hypertech ignition, Earls brake hoses, Hotchkis springs, Tokico Illumina 5 adjustable shocks and struts, Lakewood panhard and trailing arms
14.50@ 97
Old Jul 9, 2001 | 10:00 AM
LeeH's Avatar
Car: 89 Firebird Formula
Engine: 389
Axle/Gears: Moser 4.11
I have an 89 TPI harness you can look at if it helps you. I work right down the road from you in Butler...
Old Jul 11, 2001 | 09:31 PM
Guest
Guest
Posts: n/a
<font face="Verdana, Arial" size="2">Originally posted by slowTA:
</font>
Need wire colors.
Old Jul 11, 2001 | 10:46 PM
slowTA's Avatar
Car: '88 Formula
The 2 heavy wires are both orange and they go into a weatherpack. I am not sure of the others right now, I've been too busy running the fuel lines.
Old Jul 12, 2001 | 10:48 PM
Guest
Guest
Posts: n/a
The 2 heavy orange wires run to battery power, one has a fusible link (I believe the one that eventually powers the electric fan) and the other runs to a fuse for the ecm power and then to the battery.
The square shaped plug *may* be for the windsheild wiper motor, but without the wire colors I cant be sure.
Steve78LT
Feb 24, 2016 12:15 AM
ChaseDale3and8
Sep 1, 2015 01:49 PM
jer4251
Sep 1, 2015 09:04 AM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
