Traxion,question on your findings during head gaskets replacement
About a month or so I was searching around some old posts & foound your pics on head gasket replacement.I too am running a mini ram intake.You mentioned about how the mini ram affects the back cylinder a little differant.So you were going to cut back on the fuel at WOT.I have a set very similar to yours.I'm only running 24# injectors any recommendtions on what to set it at so I don't have the same problem that you ran into
91Z28
355cu AFR 190 heads,10.23:1cr comp cam
08-503-08
91Z28
08-503-08
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
The biggest telltale sign of what was going wrong was the plugs. I never really checked them. You live and learn. Now I check them
(due to all of Bruce's 'Plug Reading' rantings). If you look at the old pic you can see how black the plugs are. She was running pretty dang rich. Make me wonder what that setup would have REALLY run in the 1/4
Anyhow, now when I pull the plugs there is no soot anywhere .... no black. Just a nice off-white (slightly tan). I can't really say what I did in order to accomplish this because its like comparing apples to oranges. I swapped to a much bigger cam, had my AFR190's ported, installed the AFR HydraRev, put in a new heated O2 sensor ... .. . and then retuned part throttle and WOT (including checking plugs).
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Anyhow, now when I pull the plugs there is no soot anywhere .... no black. Just a nice off-white (slightly tan). I can't really say what I did in order to accomplish this because its like comparing apples to oranges. I swapped to a much bigger cam, had my AFR190's ported, installed the AFR HydraRev, put in a new heated O2 sensor ... .. . and then retuned part throttle and WOT (including checking plugs).Tim
NinjaNife
Aug 23, 2015 11:49 AM
