Ease Scantool users - knock retard/MAF solution
Old Jul 20, 2001 | 09:21 AM
GlennS87's Avatar
I was finding that when I cionnected to the tool using the 89 Vette signal set(I have a modified ARAP chip), that I wasn't getting good info on the MAF or knock retard. I spoke with Ease and they just sent me an update that appears to have fixed these problems. You can contact:
Susan Rocker
EASE Diagnostics Tech Support
techsupport@obd2.com
703-753-7329
for the fix.
Neptune, NJ
White '87 Vette - 383 Superram ported and matched to TPIS big mouth intake, Eagle cast crank, 6"eagle forged rods, srp/je forged pistons, LPE 219 cam, ported heads(2"x1.56" ferrea valves), Comp cams pro-magnum 1.6 rr's, double springs, titanium retainers,Hypertech power coil and cap, 4 bolt block, TPIS headers, auto(trans kit,shift kit),Pro Torque 2600 stall converter, k&N filter, 3.07 rear diff., Silver ZR-1 wheels 17x9 and 17X11
[This message has been edited by GlennS87 (edited July 20, 2001).]
Old Jul 20, 2001 | 10:15 AM
-=Jeff=-'s Avatar
Car: 1990 Corvette ZR-1
Engine: LT5
Transmission: ZF6
What is the date on the CD with the fix?
I have gotten 3 different updates since I bought the software in March of 2000.
Since mine is now out of warranty or free upgrades I believe I would like to check into it before calling
-=Jeff=-
89 Corvette Coupe White with Black Grand Sport Stripe
-=ICON Motorsports=-
Check out my mods on My '89 Vette
Old Jul 20, 2001 | 04:21 PM
GlennS87's Avatar
It didn't come on a cd. They e-mailed me the file. When I spoke to Susan today, she mentioned that GM hadn't supplied them with the right parameters with regards to the knock retard. She put the fix together using assumption taken from paremeters that worked in other signal sets. What I am going to have to do when I can find the time is due a back to back test with another scantool that definitely gives the right information. (My mechanic has a snap on scanner)
Since you are using the 730 ECM Jeff, this might not apply to you. Are you getting anything from your scantool relating to knock retard? I found it weird that I was the first person supposedly who brought this to their attention. She said it was ok if I e-mailed it to others so if you want it, I'll send it to you. Keep in mind, it's not a new version, it's just a fix so that these parameters reflect properly.
Let me know.
Regards,
Glenn
Old Jul 20, 2001 | 08:16 PM
MikeT 88IROC350's Avatar
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
I'm also interested in this update. Does it ADD the paramter called "knock retard"? I do not have that parameter currently. I have the latest version of the scan tool. I scan my stock '165 ECM, with only 1 signal set available. I have worked with Susan on other issues. I may email or call her myself.
Best ET 14.413 @95.57 without
pulling valve covers or manifolds.
Also with stock 2.77 rear end!!!
Old Jul 20, 2001 | 09:03 PM
-=Jeff=-'s Avatar
Engine: LT5
Transmission: ZF6
Glenn,
Please send it to jdebuhr@home.com
I am still using my 165 and have not yet converted to the 7730
Thanks a bunchJeff
Old Jul 23, 2001 | 09:57 AM
GlennS87's Avatar
Mike,
Yes it does. Mine was reporting 0 and I didn't believe that was possible given my setup and what I've read about L98's.
Jeff- I will e-mail it to you
Glenn
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
1MeanZ
Dec 18, 2015 05:39 AM
FormulasOnly
Sep 10, 2015 09:07 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
tgp1990
Sep 4, 2015 06:24 AM
