ECM Switch Table in Tunrcat
Maybe be sort of dumb but what do a need to disdable and leave able in this chart ie.EGR diagnostic I'm no longer using my EGR so do I shut this off.And on this VATS thing if I remember correctly I read some old post where this was causing some problem for some guys.I'm using ECM8d.and stock 90L98man8D sig
should have all of the info you need to help out.Thanks to all who have replied in the past.one more thing any idea why ever time I open up the bin and go to constants the # of cylinders is always on zero.and if you use the arrows it goes up in increments of 32 and double then keeps doubling.32,64,96,128 etc..
1991 1LE Z28 355cu 5SPD ORIGINALLY (305 BEST E.T. 14.186@99.86mph)NO PASSES ON 355 YET.MINI RAM INTAKE,AFR 190 HEADS,10.23:1cr 24# SVO INJECTORS,BBK 52mmTB,AFPR
FULL ROLLER MOTOR,MSD 6AL
AUTOMETER A/F GAGUE MARCH PULLEYS,HEDDMEN HEADERS 3IN EXH NO CATS FLOWMASTER,POWER TRAX NO-SLIP LOCKER,3:42 GEARS,LAKEWOOD LOWER CONTROL ARMS HOTCHIKS STRUTTOWER BRACE,COMPETTION ENG.SUBFRAME CONNECTORS
MALLORY TACH W/SHIFT LITE
BLACK, TINTED WINDOWS, TAIL LIGHT COVERS BIG BLOCK COWL INDUCTION HOOD,SHAVED DOOR HANDLES
67RS 327cu 92K ORIG MILES.NEWER GM HEADS HEADERS,650 HOLLEY CARB,CAM, 350 TURBO TRANS W/SHIFT KIT&COOLER 12 BOLT POSI 3.73'S MUTLILEAF SPRINGS
NEW VINYLROOF&CARPET, COWL HOOD,HIDE AWAY HEAD LITES,
[This message has been edited by chiefz28 (edited July 28, 2001).]
<font face="Verdana, Arial" size="2">Originally posted by Glenn91L98GTA:
Set the EGR MAT Temperature Counts to a very high number like 254. This will keep the EGR from operating. The constant is in the Constants Table.</font>
1991 1LE Z28 355cu 5SPD (ORIGINALLY 305 BEST E.T. 14.186@99.86mph)NO PASSES ON 355 YET.MINI RAM INTAKE,AFR 190 HEADS,10.23:1cr 24# SVO INJECTORS,BBK 52mmTB,AFPR
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Zero is the code for 8 cylinders in the $8D file. Strange but true. Look at the help file for the $8D tdf, it shows it.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
<font face="Verdana, Arial" size="2">Originally posted by Kevin91Z:
</font>
</font>
FULL ROLLER MOTOR,1.6 rockers MSD 6AL
86CamaroDan
Sep 29, 2015 10:08 PM
