Vac Regulators
Old Sep 8, 2006 | 08:50 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Vac Regulators
Trying to get setup with the EBL and Aeromotive vac ref regulator.
Fuel pressure is reduced ~1lb with every 2" of vac.
I've heard that there is a mod that allows vac to reduce fuel pressure more than the above ratio.
Anyone heard of this?
Old Sep 9, 2006 | 09:35 PM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
va454,
Which Aeromotive is it? Mine is the 13301 and I believe that is a 1:1. In fact, RBob recently "persuaded" me to hook up the vacuum line. Runs great!
Based on my experience this particular VAFPR is a bit non-linear, which RBob adjusted using the BPC v VAC table in EBL.
Old Sep 10, 2006 | 07:44 AM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
It's the regulator designed for the LT1. 13307 is the p/n I believe.
I contacted Aeromotive. All their regulators with a vac/boost fitting are indeed 1:1 ratio.
RBob also set me up with the values for my Vac vs BPC table.
Old Sep 10, 2006 | 10:08 AM
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Once RBob set up the BPC values I verified them by eye. Turns out the idle FP was a bit lower than calculated, so we re-adjusted the BPC values to take the actual FP into account. If you haven't, I would confirm the calc'd values with what's actually happening on the motor.
Mark_ZZ3
May 24, 2018 01:02 PM
gixxer92
May 18, 2017 11:20 AM
Reid Fleming
Oct 10, 2015 09:56 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
