165 from vette the same as f-body?
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Please forgive my ignorance here. I'm fed up with my 85 running so incredibly poorly. Decent part throttle response but it's a pig at WOT. All of my spark plugs are black. Anyway, there's a guy that offered an ECM from an 86 vette to me for free. It's a 165, so I'm assuming it's the same but I'm not really sure. What about the calpack and/or the PROM? I recall others saying here that the Vette works a little differently than the f-body. Any info would be a big help. Thanks.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
thanks.
The IROC Homepage
The IROC Homepage
Just did the search and realized that Mike's website is where I started this whole mess. His site says that the y and f-body used the 165, but all I'm hearing is that there were wiring differences between the two and before I try to hook up a 165 from a vette and find out that it doesn't work, I'd like to know for sure.
The IROC Homepage
The IROC Homepage
Exactly, Afgun is correct. A part number is a part number, they wouldn't change a thing unless the part/product was changed.
An example is the Speed Density computers. The Fbody used the 730 and the Vette used the 727, one is for the inside of the vehicle(fbody) and the other for the outside under the hood(vette). And of course some pin changes.
Brendan
Brendan
GM's '85 TPI cars used a different ECM ('870) and it is not pin compatible with the '165 -
http://www.eecis.udel.edu/~davis/z28/ecm_swap/
<font face="Verdana, Arial" size="2">Originally posted by 86Red4+3:
http://www.eecis.udel.edu/~davis/z28/ecm_swap/</font>
The IROC Homepage
The vette 870 was wired a little different from the camaro 870. I think they swapped the injector wires.
I did the 870==>165 swap and it is pretty simple. However do not go blindly with the wiring of the injectors on the site. For the injectors use the picture and GM wire location diagram for where the wires are and need to go. Do that and you'll see what I mean. The list in that site for the injector wires is a little off.
I have some swap material if you are interested. It consists of a diagram for the relay circuits which make the splicing easier to read, and an exel spreadsheet that lists the wire locations, what they are, where they need to go, and then for the new wiring it lists the former location of the wiring, their function, and where they are located. All that was done to endure the wired was correct and quickly traceable in case there were any problems.
James
1985 Z-28, 350 TPI, T-Tops, edelbrock 6085 heads, ZZ4 cam, accel base/runners & 24 lb/hr inj., ported plenum, everything gasket matched, crane AFPR, SLP 1 5/8 headers, single 3" flowmaster catback, 3" Catco cat, modified tranny, 165 ECM & ARAP code, MSD 6AL/wires, edelbrock STB, Spohn SFC, GW "wonderbar"
James
Yeah man, anything you're willing to share is stuff I'll eagerly take! The ECM is in the mail, so I'll be doing this soon.
I've got the Helm manual for my 85. Does anybody have the injector diagram/wiring schematics for an 86-89?
While we're at it, I imagine I may as well start taking suggestions for Prom burning software/hardware. I need it all. I burned a few PROMs in college, but never for my car.
The IROC Homepage
The IROC Homepage
I have. A couple times. I'm just trying to gather as much opinion and as many resources as I can. Thanks.
The IROC Homepage
The IROC Homepage
88SS6SPEED
Nov 11, 2015 07:05 AM
