Oil pan and Vette accessories
Old Sep 12, 2015 | 11:31 AM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
My turbo setup is a little too close to the alt belt, so I'm switching to LS2 Vette accessories, namely the wp and crank pulley (only running alt and wp). Any specific wp and pulley you guys recommend?
As far as oil pan, where can I buy a complete setup with the windage tray, pan, pickup and dipstick for my 6.0? Don't care to hunt used stuff down.
Old Sep 15, 2015 | 05:24 AM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Re: Oil pan and Vette accessories
Superchevyperformance for the oil pan setup for a 4th gen.
I run Corvette accessories. The Water pump is the exact same as a 4th gen.
Jay
Old Sep 15, 2015 | 07:40 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I was under the impression that Corvette and 4th gen F-body have different water pump.
Old Sep 15, 2015 | 07:47 AM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
Since I'm going to be running an 05 Vette wp, buying a belt tensioner is expensive.. so I found this... looks like it will work?
Amazon.com: Gates 38328 Belt Tensioner Assembly: Automotive Amazon.com: Gates 38328 Belt Tensioner Assembly: Automotive
Old Nov 7, 2015 | 02:35 PM
Pocket's Avatar
Car: 91 Trans Am
4th gen Fbody, GTOs and C5's used the same WP with the massive bell pulley. Its wide enough for both belt paths. The tensioner is unique for each accessory offset though
LS2/3 C6 WP's have a much shorter bell that only works for corvette FEADs. Late in the production they switched from pass side upper port to drivers side and used LSA WPs. These are easy to sport with the drilled/tapped bolt holes that are unused near the tensioner
Tensioners are expensive, yes. If you think the main tensioner is expensive, check out that dinky little AC tensioner
Old Nov 7, 2015 | 02:46 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Do some have integrated thermostat vs. serviceable thermostat?
Old Nov 7, 2015 | 03:05 PM
Pocket's Avatar
Car: 91 Trans Am
GEN III's vs GEN IVs. Main thing to remember is theyre not interchangeable
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
abray1
Sep 14, 2015 08:18 AM
timonator
Sep 13, 2015 11:49 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
