correct oil pan for ls1 swap
Old Sep 12, 2015 | 05:59 PM
timonator's Avatar
I just developed a hole in my oil pan because of a protruding weld on the back of my crossmember that I didn't see. Do these oil pans work with third gens ? Ebay item # 151664108660
Old Sep 12, 2015 | 06:31 PM
timonator's Avatar
Re: correct oil pan for ls1 swap
Heres a direct link :
http://m.ebay.com/itm/like/GM-PERFOR...60?_mwBanner=1
Old Sep 12, 2015 | 07:19 PM
LX_SS's Avatar
Car: 85 Firebird C&C T-Top
Engine: 347ci LS1
Transmission: 4L60E LS1
Axle/Gears: BW 9 Bolt Posi,3.27,C5+VE Brakes
From the ebay link thats a 8 inch sump, which will sit a fair bit lower than the cross member, i think the correct f-body sump sits around 5.5 inches.
Depending how big the hole is you could always get it welded up.
Old Sep 12, 2015 | 08:09 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Talk to "burgers" at LS1tech forum. He can get you new or used. FYI - a new LS1 F-body oil pan from GM uses an LS3 oil filter.
Old Sep 13, 2015 | 06:21 AM
timonator's Avatar
I sent "burgers" a pm. What is different with the ls3 filter. The y pipe that I made doesn't leave room for anything bigger than the stock ls1 filter.
Old Sep 13, 2015 | 11:49 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Thread size is different. The LS1 filter won't screw on.
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
matthew911
Aug 12, 2015 09:38 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
gwade12
Aug 8, 2015 08:17 AM
