Starting bin recommendations
Old Aug 11, 2001 | 01:15 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Hello, I'm kinda getting started in all this stuff so bear with me. I was wondering if someone could recommend a bin close for my combo to start off with. I know the ARAP is the 'best' stock type code for the 165 computer, but is there a modded version that will be closer for my combo to start with?
I'm running 388 cubes, 234/234 duration on a 114LSA. My idle (750 desired) vacuum will be in the 10.5 to 11" Hg range. 700R4 trans. with EGR.
If someone is running a combo similar it would be a great help to me if I could start with the closest .bin to start with but I have no idea how the part numbers are refc'd to on diy-efi.
Thanks for any help...
Old Aug 11, 2001 | 01:23 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by JoelOl75:
</font>
First off, I doubt you'll want to run EGR. The bigger cam, has already added alot of EGR to your engine already.
You want to start with a clean sheet of paper, on where to start. Your engine isn't exactly like there's, and who's to say you won't be building on an error on their part?.
Maybe even a serious error.
Reading thur the archives here will give answers to guestions you haven't even thought of yet.
Old Aug 11, 2001 | 01:25 PM
Brent's Avatar
If I were in your shoes I'd pick up a stock copy of AUJM from DIY-EFI.org
Thats the newest bin for a '89 350 A4 3.27
Do you really want someone elses spark table? One that could potentially be damaging to your engine? Stock is conservative and safe.
Old Aug 11, 2001 | 01:32 PM
JoelOl75's Avatar
Thank you for replies. That copy has the VATS off? I don't have vats but want to run the 89 code. I guess I could shut the vats and egr off on Grumpys rec. That cam will be rough and I'm not sure how much MAF could compensate. I got winbin but I really need something just to get up and running quickly, and fine tune later.
[This message has been edited by JoelOl75 (edited August 11, 2001).]
Old Aug 11, 2001 | 01:37 PM
Brent's Avatar
No. Stock bins in 89 have VATS enabled. You will have to disable VATS with your bin editor.
Old Aug 14, 2001 | 11:05 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I was looking through that site tryign to find an 89 350 TPI bin as well. Where are they?
Thanks!
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
dyeager535
Aug 28, 2015 08:10 AM
beast94
Aug 20, 2015 06:44 AM
ezobens
Aug 19, 2015 10:29 PM
