Datalogging with stop prom
Old Aug 22, 2001 | 12:37 PM
z28dan's Avatar
I never got a chance to do some datalogging with my stock prom, I did mods then went to the ARAP bin. What kinda knocking occurs with a stock motor and stock bin in our cars? Does the factory cut the timing back far enough to eliminate all knock? Just wondering??
1988 L98
Vette Heads/no EGR
SLP Headers/Y-Pipe
ARAP bin
Old Aug 24, 2001 | 01:04 AM
ZaphodB's Avatar
Car: Camaro IROC-Z '89
Engine: 350 TPI /w Procharger P1SC
Transmission: TH700R4 with Transgo shiftkit
Axle/Gears: 2.77 Borg Warner
<font face="Verdana, Arial" size="2">Originally posted by z28dan:
</font>
My car usually gives one or two knock counts when I first turn the key, and maybe a single knock when I really get on it....
That is both with my stock ANYJ9304 and with the ARAP code. Any more than that and your motor probably isn't very happy about the new spark table, or maybe your base timing isn't set correctly. Should be 6 degrees...
ZaphodB a.k.a Carl Andersson - zaphodb@faxancruisers.org
'89 Camaro IROC-Z 5.7L TPI - Mods under construction :-)
Custom ARAP Chip Under Development/180 t-stat, Edelbrock TES Headers,
SLP Airfoil, K&N Filters, Accel 8mm wires, Relocated MAT, AFPR @ 45 PSI
Linson
Oct 24, 2025 02:00 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
ULTM8Z
Oct 2, 2015 01:25 PM
sjorgens
Oct 1, 2015 07:54 PM
Luigytico09
Oct 1, 2015 08:46 AM
