Software glitch?
Old Aug 28, 2001 | 10:50 PM
formula5's Avatar
Software glitch?
I have a 85 tpi setup,stock prom.Once in a while code45 pops up on the highway.The light stays on until the key is turned off.The o2 reads 900-950 mv when the ses is on.When i turn the car back on the mv go back to normal and no ses.Other than that it runs fine.Could the tps voltage a little high make this happen?
Old Aug 29, 2001 | 01:18 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by formula5:
I have a 85 tpi setup,stock prom.Once in a while code45 pops up on the highway.The light stays on until the key is turned off.The o2 reads 900-950 mv when the ses is on.When i turn the car back on the mv go back to normal and no ses.Other than that it runs fine.Could the tps voltage a little high make this happen?</font>
Doubtful, but if in doubt the min idle and IAC should be redone.
45 is rich, there are a bunch of parameters that must be set to throw that code, one being a timer. So after you power down the timer is reset. reading rich when in a fail soft mode is normal
Deemax
Sep 12, 2015 06:53 PM
92firebirdguy
Sep 10, 2015 10:33 PM
86camaroman201
Aug 19, 2015 04:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
Anniversary-SS-man
Apr 22, 2001 04:18 PM
