Re-learning BLM values???
Old Aug 23, 2001 | 03:50 PM
Sarkee's Avatar
When you change a value in the EPROM, and burn the new chip, the values in the BLM table are still the old values from before the changes, right???
Is it good practice to (somehow) wipe out the old learned values and drive for a while for the ECU to learn the new values??? (Or will driving overwrite the values without any coaxing from me)???
If so, how to erase the old values???
(Sorry if my terminology is off - still learning!)
Old Aug 23, 2001 | 04:09 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
You erase BLMs the same way you erase codes, just unplug the ECM fuse in the engine compartment.
And yes, i reckon it's good practice to do so after major changes, but if you only do a few tweaks at a time it is still relearning whether from baseline or not.
...ed
Old Sep 5, 2001 | 09:46 AM
Sarkee's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Ed Maher:
...ed
</font>
I just checked my timing and figured I'd reset the 42 error code (from the EST wire being disconnected) using that fuse you mentioned...But I can't find any fuse in the eng compartment...I finally just unhooked the battery ground...
This is an '86 Vette; but if the F-body has a ECM fuse, this should too...Where is it located on the F-body???
TIA!
Old Sep 5, 2001 | 10:29 AM
Brent's Avatar
F-bodys have it right near the battery in a single socket holder.
Old Sep 5, 2001 | 12:15 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by Sarkee:
</font>
If your serious about soing chips the install a switch on the Orange Bat wire near the ecm. Also makes for an anti theft devise. The orange lead is the mainpower to the ecm, the pink/black just tells the ecm to wake up.
Mark_ZZ3
May 24, 2018 01:02 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
ULTM8Z
Sep 16, 2015 09:15 AM
